sensor lowering
98LSC32V
Bay Area
Anyone got pics of relocating the sensor bracket, or what to do to get the car really dropped?
No pics but the front I drilled new holes in the bracket that mounts to the body. I believe I drilled a new hole lower on the bracket to raise the senor. But it might be the other way around. The rear has the sensor on the driver side lower a-arm. I also redrilled the bracket on the a-arm and bent it some more. I think the rear bracket needs to be lowered opposite from the front. I drilled it very close to the bend on the bracket and bent the arm down to further lower the rear. Its very easy needs alittle trial and error. to get it just right front to back and side to side.
Have you looked at all the sensors and brackets. If so you should get the idea.
That's the way I did mine. You have to drill new mounting holes in the front brackets. The front sensors must be raised to lower the front since they mount to the upper control arms. In the rear I didn't modify the bracket at all. I just adjusted the sensor down to lower it since the sensor is mounted on the lower arm in the back. There is a pretty fair amount of room to move the sensor on the rear bracket.
