sensor lowering
Jeffguy11
Wethersfield
is there a step by step guide to sensor lowering the mark viii? I just want to lower my car maybe 1/2-1 inch and the search on the forum never seems to work out for me in finding what i need to.
jeff,
You can probably do what you want to do by just using the original adjustments ! Try that first , if it is not enough , follow the direction provided above !
Good Luck,
Sonny
Sonny Day Out said:
jeff,
Good Luck,
Sonny
i wasnt aware that there were original adjustments.... im not looking to slam the car, its just that the front appears to be about an inch higher than the rear and i was looking to balance the look out- the rear is at the height i want. Is the original adjustment pretty much self explanitory when i look at the height sensor mounts?
