tireman
2001 V6, there is a "U" shaped connector that links the throttle cable to the throttle body arm. This "U" shaped piece has two clips that hold it. If the top clip comes off "mine did" the piece works its way off the throttle cable and you're stuck.
I was in heavy traffic when this occured. You still have impulse power from the engine idle that will get you off the road but no throttle.
I took a match book cover, punched a small hole in it and reset the piece to get the car home.
