2002_lincolnLS
Custom User Title
Issue, P0171 and P0174 Lean on both banks and no other codes. Intermittent issue. Runs fine, just annoying having the light pop up
2002
v8
110,000 miles
new fuel pump and strainers
new pressure sensor
filter: newer
New O2 and catalyst sensor on bank two
Doesn't seem to idle or run poorly
I am thinking a leak somewhere to cause it to run lean on both sides. I plan to test this theory today if the rain slows down. Should I use starter fluid to test the lines or any better spray type items?
Not sure what to check after that, that is not to to invasive. Have to go to work in the morning so don't want to break some obscure part that no one has in stock. I only do that kind of work on Friday nights so there is plenty of time to get parts.
2002
v8
110,000 miles
new pressure sensor
filter: newer
