Running coolant temp?
rgorke
Camarillo, CA
knowing that the gauge in the car has a huge range, I have been periodically running my OBD2 through my iPhone.
My coolant is usually in the mid 210s. The highest I have seen is 217.
Is that good/normal/bad? Where do you guys run?
Thanks
The PCM goes into full fan speed @ 239deg. Overheat registers somewhere north of that.
So the PCM considers anything under 239 to be OK. These things run toasty.
