Do you know any of the service history?
Assuming you know absolutely no service history on it, with that mileage, I would have the transmission flushed with a filter change, check the brake pads and rotors, do an oil change with good 5W20 synthetic (or Motorcraft 5W20 semi-synthetic) and a quality filter (no FRAM bull:q:q:q:q -- Purolator or Motorcraft are good), change out the fuel filter (probably never been done before), and you might want to replace the spark plugs with Motorcraft SP-468 or NGK Iridiums (I believe). If you want to go with Motorcraft for plugs, look for the thread I made recently with an eBay link for the plug pretty cheap.
If you inspect the brakes, I would pull the caliper off and grease the slide pins. I found one of my front slide pins was completely seized and I had to tap it out.
Routine maintenance on these cars isn't really any different than other cars.
