Ryanlsc123
To all the LVC gods.....
I have a 2003 ls, V8, 120,000mi. And I have a problem...
When my lincoln is cold (ie. sat longer than 4 hours since it has been run) I will start it up to go somewhere, and it has a hesitation at minimal throttle to the point it sounds like it will cut out.. If I give it more throttle it will smooth out and run fine.
It also has a bit of a lag when warm and you mash the gas away from a stop light. But if I drive normal it seems ok... Please help if you can....
