(Robs) Tune 02LS VS 05 LS + Question:
lincoln_zero
ICE COLD CANADA
Just Dragged my own cars.
2002 Lincoln LS: 2005 LS: Stock
-Megnaflow
-custom intake
-Robs Tune (don't ask how i got my hands on this ;) had it from long ago)
From the Dig, my 2002 was slipping like a fat man on soap in a shower.
The 2005 took the lead and the 2002 played catch up. At 180Km/s the 2002 quite literally went sailing by the 2005. It was epic. Even tho the 2002 couldn't stick for a good 3 seconds, and lost badly from the Dig, she whooped the 2005.
The second run was given to the 2005 as again the 2002 couldn't grip, and was just sloppy, and failed at the catch up process. The third run was the same result as second.
Cant figure out why the 02 didn't play catch up in the second and third runs as well as it did in the first race? It was FANTASTIC in the first, even tho it slipped almost the entire first gear.
The only thing i did differently from the second/third run and the first race was on the first race, i launched using the break (pre-load the rpm). But i slipped badly yet won. Second and third race i just accelerated without pre-loading the rpm and couldn't catch up, until i hit the 4th gear. By then its too late, the 2005 has it (QM).
What do you guys make of the BIG diference between the first run and the latter two?
And now for my question::
Im sorta noobish at tuning. So forgive me for asking, but can i run Robs Tune on the 2005 LS or will it require a different tune?
Haven't heard of Rob's Tune. Could you elaborate. Also, at 180km/s you must have been bookin it!
Do a search on Ills, he is no longer active on this site, or at least hasn't posted since August 2011.
as for the first race, he may have tagged the limiter and lost all momentum going in to the next gear. do it bad enough going in to third and it would really make a huge difference.
Anywhere i can get a decent 2nd Gen tune?
And both cars were raced in D5 (select shift wasn't used)
Relaying of information would lead me to say that Torrie at FastPartsNetwork.com offers LS tunes. Quite a few folks on here have them. Either that or a day on the Dyno at a reputable place.
