rcvxl14
Hey guys I just bought a Boyo VTL375HD for my 2001 Lincoln LS with a Pioneer double DIN stereo and installed it yesterday. I hooked up yellow RCA plug into the radio as directed in Pioneers instructions, wired the red power wire from the camera into the red 12V ACC wire from the head unit, and grounded the black wire. I tested the setup the way it was just to make sure that the camera worked and everything worked fine when I manually selected the rear camera source on my radio. Now I just had to wire it so the camera would automatically come on when I put the car in reverse. Pioneers directions say that the violet wire coming from the HU's harness must be wired to a reverse signal wire that changes voltage when the car is put into reverse. I tried to find a wire up in the front of the car by the gearshift, but I had no luck. So I decided to wire another separate wire from the violet HU wire all the way back to the reverse light that comes on when the car is put in to reverse. I wired this separate wire to the yellow wire that comes out of the lamp in the trunk and tested the voltage and sure enough I got voltage when I put the car into reverse. So, I soldered everything up and put it all back together and the camera still doesn't turn on when I put the car in reverse. I tested the separate wire I installed (I started at the trunk and worked my way to the center console) to make sure it was getting voltage and it was.
To the experienced wiring guys out there, am I missing something? I feel like I did everything correctly but the head unit obviously cannot tell when the car is being put into reverse. Any help is appreciated. Thanks!
