devilchild
yes i have searched.. and no that didnt last long as my patience is becoming non-existant as i get older..
its hard wired.. and i am DEATHLY scared of electricity..:shifty:
do i disconnect the battery ??..
do i use basic connectors and some shrink tubing ??..
should i attempt to clean the bulb with anything prior to install ??..
where should i cut the old wire.. or is there a way to unplug farther down so i can do the splicing out of the car ??..
what exactly do i use to remove the old bulb ??.. looks like a torx driver to me
and is there a way that i can adjust the headlights myself ??.. one seems to be pointing towards the ground more and it drives me nuts
i have replaced pigtails before.. they seem simple but they do not read " high voltage.. may cause death" on them :shifty:
i will try to take as many pics as possible before , during , and after install so maybe it could be used in the tech section
