replacing coolant tank
just got to get your hands in there to get to it unless you have a prair of hose remover pliers which you can get at Autozone i think
If I recall..remove the drivers side wheel, then pull off the wheel well liner. You will find access holes there specifically for that hose..
+1 on accessing it from the drivers wheel well. I did mine that way and only took me about 2 hours from start to finish.
