Replaced Rear Hub Assembly (bad bearing)
mharrison
Madison, Mississippi
I just replaced the right rear hub assembly on my car this morning because I had a bad wheel bearing. Man, it is Soooooo quiet now! It sounds like I'm traveling in a Lincoln!
If you do this be sure you order a new axle nut. (which btw takes a deep 36mm socket to remove/re-install). The part number the axle nut, that my local FLM could not find is XW4Z-4B477-AA. Team Ford got me the hookup on this.
The whole process took about an hour. Easy fix. IMHO.
Thanks to 00ls-sport who hooked me up with great pricing on the hub assembly. I'll be installing the new passenger side window regulator he got me next weekend!
