rear sylenoid clicking
tda13
Quincy
Not sure what the problem is, after I start my car and the car levels, the rear sylenoid clicks about every 5 seconds. The rear of the car never does level out and will at times sag.
Also, when I shut the car off, the sylenoid will continue to click the same way.
Any ideas???
Replace the sylenoid???
I would check the wiring. It will only open when it gets power, but if one of the wires is shorted you may have a problem.
Do you have any mods done to the air ride?
Yep... I cant believe I did not check the harness.... Rays Kit.
Thanks
Ah... I bet thats it. Would make sense that something is lose or faulty switch. Let us know!
OK... Checked all the wires and everything looks good. Even unhooked the 12volt to the kit to disable it and I still have the same problem. What is really weird, when I shut the car off and take the keys out, the rear sylenoid will continue to click about every 5 or 6 seconds until the rear bags are vented?!?!?! It does this with the kit dissabled as well.
Any ideas??? Sylenoid???
By the way, the car is sensor lowered as well.
UPDATE:
Now when the compressor kicks on, the front fills first and the back will only fill for a couple seconds, then the solenoid clicks and the compressor turns off for about 5 seconds, then it kicks on again for about 2 seconds then off for 5 and so on. I have completly unhooked rays kit to eleminate this as an issue.
