Rear Sway bar bushings
93mkviii
jacksonville
My rear sway bar moves from side to side. In other words if I grab it and push and pull on it from the side of the car it moves about 2 inches. What should I look into replacing? End links or bushings?
Bushings most likely, have you looked under the car to see what any of them look like?
The end link's bushings on the top are mostly teared off. And the two support bushings(don't know what to call them) seems to have wear and tear. Now if I have replace all the endlinks and bushings I might be looking for a whole set for the sway bar instead since the sway bar also has orange(rust corasion?) spots.
broken rear sway bars are a problem with the gen 1. if it was driven much slammed they don't stand up. jd
