Rear outside door handle broken off and can't open from inside either.
atikovi
Suburban Washington DC
2000 model. I assume the child safety switch in enabled so I can't open the door from the inside. The outside handle that you grab is missing. I tried probing the hole where the handle should go with a hook tool but got nowhere. Any suggestions to get it open?
It may not be that the child lock is set. When the outside handle was broken off, it may have taken the rod the works the latch with it.
I do remember a thread or two on here about this problem. I think that generally they ended up breaking the interior door trim off to be able to get to the door latch.
I found a color matching handle in the junk yard and could see it's bolted on the door by just two studs. Using a hand grinder with a 1/16th 3 inch cutoff wheel I sliced through the handle from the outside and removed it in 2 minutes. Door then opened with the linkage. No damage.
