Rear Lower Control Arm Availability and Compatibility
rgorke
Camarillo, CA
I have a very annoying squeak from my driver's side rear end. I used a mechanics stethoscope and am fairly certain it is coming from the LCA. I sprayed some silicon lubricant into the bushings and the terrible squeak has receded.
Looking on RockAuto, there are Mevotech arms for a 2003 (states up to 11/18/2002). I am not super keen on the Mevotech products but they may be ok if I plan to use my OEM arms and reload the bushings with Poly or Jag bushings.
Anyone use LCAs from Amazon? I am sure they are similar in quality to the Mevotech.
There are some Lemforder but they are >$300 each.
Can anyone confirm the compatibility of later Jag rear suspension parts? The ones that I have seen surely "look" like they would be compatible but looks can be deceiving. Specifically arms from later S type, XF, or even XK. I was thinking of calling my local Jag dealership to see if they could confirm that 2000-2002 suspension part compatibility with later models.
