Well since my previous thread has changed direction into an entirely new issue, I thought it would be better to just start a new thread.
Old thread RE possibly leaking half shaft seals: http://www.lincolnvscadillac.com/showthread.php?t=81839
Anyway, my current issue is a popping nose coming from the rear end, passenger side. The noise happens when braking, turning, straightening the car following a turn, or even when driving on uneven surfaces. To me, this suggests that it could be the subframe (searching points to other owners with the same symptoms under the same conditions), or perhaps (and hopefully) one of the control arms. The noise is only present when the outside temperature is warm, about >10C (50F). When it's cool outside, the car is absolutely silent. When it's nice and warm, the noise is very apparent, but difficult to hear from the outside.
I posted this picture of a cracked subframe bushing (passenger side) in my old thread:
Some relevant information:
Any thoughts, ideas, feedback, etc would be greatly appreciated, along with ways that I could attempt to diagnose this myself.
Thank you.
- I attempted to tighten the bolt, but it is already very tight, way above the torque specs it seems.
- While swapping on my summer wheels, I pried on the LCA's inner attachment point (closer to the front of the car), and was able to move the arms on both sides up/down slightly - is this normal behavior of the rubber bushings?
- With the passenger rear wheel in the air, I checked for play with the 9&3 and 12&6 o'clock hand position test, but everything was tight
- Also, sometimes when rocking the car side-to-side, I can hear a metal-on-metal clunk coming from the passenger rear side.
- My toe links are infested with cancer
- End-links replaced 2 years ago
Thank you.
