Rear door locks won't function electronically
Have you tried pushing the door inward (more closed) from the outside while trying to unlock it and then open it?
Probably won't help, but it might be worth a try...
Yep , both from the outside and after I climbed through the passenger door from the inside. It hasn't worked all weekend. This is going to get old. Real quick! I thought maybe it was frozen but it was 50 here today and hotter in the car with the heat on. I guess there's still a small chance it could be frozen but I'm betting on broken
A couple weeks ago I get a text message...
Short - "Help. My door won't close. You ever have that problem?"
Bull - "Uhh, no. Mine all work fine"
Short - (Sometime later) "Oh crap! I dropped a pen in my door jam! Fixed!!"
Not to be petty but in my own defense this was my passenger door and the pen was over looked. The door latched perfectly after i locked it then shut the door. Found the pen later grabbing some paperwork from the seat. Once again, totally different situation here.
I don't need a herd time here damn it! I need some advice on getting my stinking door open so I can fix my lock. :p
Thanks nelliott ill call AAA and see what they can do.
I've heard that it may be cheaper to break the plastic exterior door handle and pop it out of the hole to get to the latch inside than to destroy the interior skin.
