Rear Defogger / Radio Noise
Rapidtransit
New Jersey
I have a 2001 LS V8. When I use the rear defogger, only the upper portion seems to clear leaving the bottom still with fog. Also the radio develops a lot of static when the defogger is switched on. When I switch the defogger off the radio plays normal. I checked with a magnifing glass to try to find a break. I think I found a weak spot. When I took a piece of wire and jumped across the two weak points, it made no difference, the radio still had static.
Any ideas would be appreciated.
Isolation module is bad, or the wire is loose going into it. It's under the top deck in the back, acessible from the top once you get the cover off...
