Rear Courtesy Led Swap Help
Crus8der09
Charles County Area
First I hope this has not been discussed somewhere else but I could not find it and I am a Newbie to posting here. I have been a fan and follower of this site for some time. I just began modding my 04 LS V8. First up Led light swap and would you know it all was going well until I swapped out my rear courtesy lights the minute I unscrewed and dropped them out of the liner they began acting like they were shorted. Not to mention in the middle of swapping both sides the casing popped off with the 3 wires that go to the on off switch. Does anyone know how to out this back together correctly. I know they are wired correctly because when i connect the bulb and let them hang both come on when the doors open and go out with the front after some time, but when i go to mount them back in place they seem to short. So really i have a to fold question
1. is this short activity normal or am i jacking something up?
2. how do you fix the switch for the light it has com completely apart?
Oh yeah before I am asked the reason I had to completely remove the casing for the bulb was because my led was to big to go back in the hole where you pop the connector out the back. Any and all help is appreciated.
Also I have completed the front map lights, license plate, reverse lights and once I figure out how to get the rear courtesy working again I complete with swapping the puddle lights and head lights. I think I read you can swap the glove box does this just pull out or do you have to drop it from the 2 bolts that hold it in.
