Dave 88 LSC
Guys, for some reason, from time to time the rear of the car is sitting at a different height. Sometimes its about an inch higher in the back than normal, but most of the time it sits fine.
This only happens with the car on, once I get out and turn it off it goes back to normal. Its as if the compressor is pumping up the rear more than its should sometimes.
Any clue? dead spot in the sensor?
Also, is it possible to lower the rear sensor without the lift? Need I take off the tire?
Thank you.
Thank you.
