mharrison
My car ran hot. I didn't see the gauge until the idiot light came on DING DING DING....
Pulled over immediately, turned off, blown water pump outlet hose.
After a LOOOONNNNNNGGGGG story, the cooling system is now ok.
The car ran like crap when I first started it after getting the needed hoses replaced. It acted like it had a 3k RPM rev limiter on it. I thought this may have been the "limp home" mode. So I pulled the negative cable and let it sit.
I looked around and there was some anti-freeze around the valve covers. I rinsed everything off with the hose, blew it off with my compressor, and left it. A few hours later I started it and it is better, but not right.
It runs like a paint shaker from time to time. Accelerates slowly and 10 miles later threw a CEL. (I'll be reading this tomorrow when I get Dad's code reader.) Sometimes it seems like all 6 are firing, but only in the upper RPM range. It will sit at a light chugging then spmetimes smooth right out like it's firing all 6 again.
Do you think I've got anti-freeze in a plug well killing a Coil? It's obviously not running on all 6 cylinders.
Suggestions, comments, prior experience?
