Okay, so I am going install a nav system. I got my new double din plate from LS Koncepts (thanks Ken), but I have no idea how to remove the factory radio. Any pointers would be appreciated.
Best way is to use a butter knife. Stick it into the sides of the top air vent bezel and pry forward gently. This will expose the top two bolts. Next take out the trim piece around the shifter with the butter knife stuck into the area around the shifter and pry up gently again. Then that will expose you to the screws for the ash tray.
Once the ash tray is out you will see the bottom two bolts for the radio. Its very easy.
