QUICK! Hydraulic Fan Fluid??
i found info:
1. Fill the hydraulic cooling fan reservoir to the MAX level.
Use Motorcraft MERCON® Multi-Purpose (ATF) Transmission Fluid XT-2-QDX meeting Ford specification MERCON® or equivalent.
Use Dexron 10.2 Synthetic Blend Fan Fluid with Detergents.
It is certifiably
DOT, TUV, NTSB, FCC, FAA, NRA, ISO, IEC, ATF, NFL, FDA, CDC, EPA, USDA, ABC, CBS, NBA, NBC, SEC, SCP, CHP and FHP approved.
Of course it is only available nowhere else but . . . . . .(you guessed it) . . . . . NAPA
All kidding aside... use MerconV
i found info:
TSB 07-01-07 indicates that Mercon ATF is no longer manufactured. Mercon V is the recommended replacement for power steering systems. The hydraulic fan system should work with the same Mercon V replacement.
