Quick ABS question
SleeperMark
Novelty
While replacing the lower ball joint on the right front my ABS sensor got pulled a little to hard. Im thinking its as simple as a broken wire but i have no ABS or TC at the time. this doesnt bother me because i dont really need either (having the knowledge of letting off brakes stops skidding) but what bothers me is the ABS pump randomly freaking out. sometimes it well engage and apply brakes and sometimes just moan. Can i pull the 30A fuse (slot 20 or 21 i think) until i get this wire replaced so i dont cause any damage to the pump? or does this fuse connect to other systems? Thanks
also, where can i get a right front sensor for a reasonable price? rockauto.com has it but they want $100. Sounds a little high
Find out where the wire is broken and fix it temporarily so you can get a good sensor and keep all the modules happy is the easiest solution
Well since I'm actully a " Certified Brake Safety Expert" I would advise you to replace the ABS sensor, but yes you can pull the fuse to keep the pump from kicking on
I will look in the back room tomorrow for you, i've probably got a few extra laying around, if I do I can send you one
Sounds good. thanks guys. And if u have Sapperfire one its the right front i believe. Just MSG me if you do. Thanks
