pulsing vibration
deadmark8
beaver dam
well its been this way for a bit but i dont know what it is. at speeds above 35mph i have a slightly annoying pulsing vibration, it gets worse the faster i go, although if i accelerate it stops till i get back to cruising or light load. tires are good it needs tie rods, so i been told, and i dont know how many miles are on the front suspension...
any ideas would be helpful
steven
Could be drive shaft. But usually that is more pronounced at higher speeds and not felt below 55.
Try putting it in neutral next time. It will take the load off the drive train. Might help in figuring it out.
I would vote driveshaft...
As the u joints start to fail they make the shaft vibrate worse and worse...
