Projector headlights...need oem headlight harness
00ls5spd
Bonita Ca
I am taking apart my projector headlights and parting them out. I am going back to my stock setup with silverstars. I am gonna keep the angeleyes but I feel the projectors kinda take away from the neatness of the front end. It just doesn't flow with the look of the car.
I need the oem headlight wiring harness if anyone has a set laying around. Mainly all I need are the lowbeam plug ins.
I'k not gonna sell them already put together. Because I need the the headlight lense from the projector headlight to put on my old headlights( I need the color matched eyebrows) and Since I am keeping the angeleyes, it wouldn't be worth the money (IMO) for someone to buy them. I will however sell the parts at a great price and you guys can make your own.
Parts for sale:
BMW E46 Projectors $100.00 for the set (includes bulb holders)
BMW D2S 4300K Bulbs $50.00 They cost alot more but since these are used I will take a loss.
Infiniti G35 Ballast with internal ignitors $100.00
Check this stuff out on ebay I am letting this stuff go for cheap. If anyone buys this stuff I will give an indepth how to so pretty much anyone can do this project.
I did the change over yesterday and I must say besides the coolness of the look of the projector I like the clean look of my oem headlights better. They flow with the car much better as well. I will post some new pics tonight. BTW I switched them out to the hoen xenon match plus setup from LSKoncepts. I still have the projectors for sale too.
Do u guys know of any1 who has projectors in the 05-06 headlights? All headlights with projectors Ive seen are like mines, with both hi n lo beams the same size, Im thinking about getting a front fascia kit along with the newer LSs headlights I wanna put projectors and angel eyes but I havent seen any1 with projectors into those headlights.
Bulbs and ballasts are sold!!
Projectors still available.
Still have the projectors? why everybody look for E46's projectors? whats so special about them. Ive seen infinitis cut off line and I think they re insanelly hot!
Also, how hard is it to install em the right way and have both right n left set at the same angle?
I have a pair of headlights Im messing with, u know trying to build my own angel eyes, take off the amber lense, and put projectors in it!
It wasn't hard to get the projectors level. When I built the lights I just laid them next to each other and eyeballed it. The projectors have the center piece which is the cutoff line built in. All u have to do is line them up with each other. Aiming them wasn't a problem at all either. If done right you can use the original aiming screws on the headlight assembly.
I belive the formula for aiming is like this:
measure from the ground to center of headlight (horizontal). Then on a flat surface such as a driveway, (It needs to have a wall or garage door to aim at though.) Measure out 25ft and place your headlight there(installed in the car of course) then on the wall/garage door measure out your hieght from ground to center and that will be the reference point for where the cutoff line is suppost to be.
