Travis2000LS
Okay so heres the scenario... two days ago im just driving along and I notice my wonderful 2000 lincoln ls v8 beeps at me informing me that I need to check my engine temp. So I look at the gauge and TADA ITS HOT BABY! So I pull in a parking lot and turn off the engine immediately. Open the hood and notice a boiling noise.. Then Im guessing my LS got sick and threw up Anti-Freeze out of the Degas cap because pressure was to high. Im like WTH!?
SO I go out and buy a new thermostat thinking that the thermostat is bad and go stuck and not letting water in.. So I replace the thermostat yesterday drive 7 miles out and TADA Its hot again.. Im at a loss? The water pump is good. The fan is running fine, blows hard. Thermostat is brand new. and The Old one once i boiled it in water opened up as well. Its not leaking Antifreeze on the ground or anywhere else until it gets way to hot and leaks it out of the pressure cap..
What could this be... I have heat also.. So I was wondering if there was air in the system causing this? so i filled it up with water open the fill cap blah blah blah.
But for some odd reason apparently my Lincoln LS 3.9L V8 doesnt have a Heater Air Bleed line? Ive searched in the place its suppose to be and everywhere else no dice..
So If anyone could please shine some light on this... I would be in great debt to them..
