Problem with my air ride on my 93
bobotech
spokane
Okay, I just replaced the lower control arms, the upper control arms, the wheel bearings, and brakes on my 93. I had to take the struts out. Yesterday we did the passenger side.
We put one of my used struts in place of the one that I think was leaking on thge passenger side. Problem was that the bag wasn't centered around the strut so when it inflated, it inflated all weirdly and blew.
So today we put the old strut back in and then replaced the driver's side parts. Put the same strut back in on the driver's side.
Problem is that my air ride refuses now to pump up at all. the really weird thing is NO check air ride message. I turn the switch off and it says "Air ride off" then turn it back on but nothing,. no pumping up.
This morning after I replaced the passenger side strut with my old one, I checked the air ride and it pumped up fine.
Its only after doing the dirver's side that it refused to pump up.
No air ridde messages which really confuses me.
Help!
More weird info. My ABS light is on now too. Just the ABS light. Also the alarm keeps going off if I arm it.
where the hell should I start looking?
Well I fixed it.
Turns out there is a fuse in the cockpit fusebox that controls a few things. It is number 10. The fuse was blown causing my air ride to not pump up, the ABS light to go on the dash and oddly enough, caused the alarm to go off after about a minute.
Replaced the fuse and it works fine now.
