jmathls01v8
New here and all the info has been really helpful, but I ran into a problem. I, just finished replacing the left head and the primary and secondary timing chains on an 01 V8. Finally got everything back together and I tried cranking the engine by hand before I started it up and realized I put the cams from the old head into the new head. Of course I had to take the master link out of the primary chain to do that, and now I need to compress the tensioner so I can get the chain back on the cam. Is it even feasible to get to the check valve on the tensioner without taking everything back apart to get the front cover off?
