put the car on jackstand securely witht he front wheels off the ground, go to the rack on the driver side and find the 10mm bolt holding the power steering lines in, remove the 10mm
Pull the lines out of the rack (make sure you have a drain pan under the car first)
Let them drain, then turn the wheels (by grabbing the wheel/tire itself and turn it from lock to lock to till you force all the fluid out of the system.
Then reconnect lines and fill the power steering resivior. (on the driver side of the car)
then turn the wheel lock to lock while the car is still in the air with the engine off to help get some of the air out.
then make sure its full. Start the car and let it run for a few little bit, it will probably make noise. Turn it off after about 15 seconds and let it sit for a minute.
Then make sure its full start it up again and turn the wheel some, repeat untill the noise goes away.
gl its not that bad to do.
Jay
