power steering fluid
98LSC32V
Bay Area
How many quarts of Mercon 5 do you need for a power steering flush?
the power steering system in a mark VIII calls for mercon fluid. I would double check before using mercon 5 in it.
I swear, AllData is useless at times...
I remember buying a Gallon of PS fluid when I put the motor in. Replaced the Rack and pinion, and put in a new pump, IIRC it took about 2 QTs.
I was actually gonna use the Amsoil universal ATF which meets and exceeds Mercon/Mercon5 specs. In their product lookup guide it's what they recommend for Mark VIII power steering fluid.
My '93 originally called for Type F fluid.
Sometime later, Mercon became the proper fluid.
It's okay to use Mercon V in applications that call for Mercon.
See here.
I wouldn't use Mercon in somethng that calls for Mercon V though.
Might not want to use Mercon V in an old rack, you are asking for leaks. I used Merc. 3 over two mos. ago no probs. and everything quieted down.
IIRC it's just over 2.25qts. Might've been 2.25 pints, that seems to stick out in my head for some reason, but I think it was 2.25qts.
