rayner601
I have a popping noise in the intake. It happens when you let off of the throttle after revving the engine from idle to about 1200 RPM. It isn't a backfire sound just a gentle thump you can hear in the air filter housing. When it does this, the IAC also buzzes. It will also let the idle lope about 300 rpm and the IAC is buzzing then as well. Cleaned IAC, plugs are autolite platnum gapped at factory specs with about 15k on them, fuel pressure is 30 at idle, 35 under load, 35 with regulator hose unplugged. I am leaning towards a fuel pump and or IAC. Any help is appreciated.
Joe
Joe
