HyeLifeLS
I have been having this oil leak from what it seamed like the oil pan gasket for few months now and decided to attack it. As some of you know the V6 oil pan is a PITA to remove, gotta take apart half of the car pretty much, changed that and also noticed that front main seal had a leak, changed that too while I was there. Put everything back and couple of days later noticed again the leak continues. Had the car on the lift at the alignment shop and noticed that it is coming from a bit higher than the oil pan. I think it is called the secondary oil pan or oil pan spacer, not sure, but looks like oil leaks from top of it. When I was under the car it didn't look very clear on how to remove that part when I had the oil pan out.
I talked to my mechanic and he suggested puting a dye in the oil to see where the leak is from exactly. Might go do that in next few days, he also said that to change the gasket on top of that spacer the motor needs to be out and it is a big job, it does look like it, but I want to see if any of you guys had a problem like this and what was your fix for it.
2001 V6 Sport Auto 277400 miles.
