Overdrive light question...
Stangman
Project car a.d.d.
Sardinia, OH
First off, my overdrive works just fine.
My question is, does the light not coming on have anything to do with the switch on the shifter?
I can press the button to deactivate o/d and the light doesn't come on sometimes. Generally it won't work most of the day, then start working later in the evening if I am actively driving it all day.
It never did that before I totalled it. But overdrive on/off function works as it should. Sometimes I just can't remember when its off or when its on.
Is this in the switch or would you say its a dirty connection near the bulb?
I have another display to swap and try but have to clean it up first.
The power to it is in a harness under the console, just about where the cup holder is , runs under console carpet. Might be a loose conn on that harness , former owner on my mark had that harness un hooked . So I had no shifter lights and no od controll . Just a thought or you just may need a new bulb on the disp center.
