Opinions
HotShotp2000
Belleville
After doing some searching I found that people are not happy with the SCP suspension products. I plan to redo the entire front end most likely using TRW but had a couple questions regarding other SCP products.
I previously purchased/installed the poly rack and pinion bushing kit and the rear differential poly bushing kit as well as the rear spindle poly kit. So far I've had no problems but are these particular kits inferior to others? If so, which complany would have the best? I just want to make sure absolutely everything is all set before the last phase is done (blower).
Thanks
