O/D switch for arming N2O system?
twinbopilot
Dallas
What are your thoughts about using the Overdrive-off switch on the shifter to arm a remote valve opener on the N2O tank, then use a WOT switch to activate the nitrous?
Don't get me wrong, the OD Off switch would still work as normal, but I'd use that output to open the N2O bottle's remote-control valve. Even through a relay, if required.
I mean, you don't need OD when running on the bottle. Do you? Unless your at the salt flats or something crazy.
So am I missing something, or could this work as a tidy install solution?
