guinnessman
Hey guys so i've read sooo many posts and internet write ups on when to use/when not to use Overdrive etc etc. I cannot find a solid piece of info that says exactly WHY you should or should not do the following.
I always drive with o/d off when driving under 55mph-normal street stop light to stop light driving etc. I'll hit the highway, then i click the button to enable the overdrive band for MPG increases of coarse.
Driving like that, i've read so many different things, some say it is bad for the tranny, that it causes heat in the fluid because it is not shifting into O/D. I've read that your converter can balloon from heat etc. Something about torque converter lockup?
When it comes down to it, i simply would like to know what exactly happens in the transmission when you are riding 30-45mph in 3rd gear with o/d off..does it burn the fluid faster, harm the tranny in anyway?
If you can please share your knowledge on this, it is greatly appreciated.
