Passenger side rear of engine coil.
Rockauto.com if you want OEM coils. Ebay if you want cheap coils. Below are the instructions on how to change a coil out. When changing this coil out, look for oil in the spark plug wells. If oil is found, your valve cover gaskets are bad. Rockauto.com 45 bucks if i remember right. Change out all coils that have had oil on them and then all 8 spark plugs.
All ignition coils
Remove the 12 bolts and the 2 ignition coil covers.
Remove all silicone sealant and residue from the coil cover.
Remove all silicone sealant and residue from the valve cover surface and ignition coil wiring harness.
Disconnect the 8 ignition coil electrical connectors.
Remove the 8 ignition coil bolts.
NOTE: When removing the ignition coils, a slight twisting motion will break the seal and ease removal.
Remove the 8 ignition coils.
Installation
All ignition coils
NOTE: Apply silicone brake caliper grease and dielectric compound to the inside of ignition coil boots.
Install the 8 ignition coils and the bolts.
Tighten to 5 Nm (44 lb-in).
Connect the 8 ignition coil electrical connectors.
NOTE: Remove all dirt and moisture from the valve cover before applying silicone sealant.
Lift up the wire harness and apply a 12.7 mm (0.5 in) bead of silicone sealant in the notch of the valve cover.
Set the ignition coil harness in the bead of silicone sealant and apply enough additional sealant to surround the wire harness and notch.
Install the ignition coil covers and the bolts.
