Spree
Yesterday I replaced all the white light's in the dash and console with blue led's. Took it for a drive and everything was just fine when I parked it. Tonight I get in and no dash lights or console lights even the ash trey light doesn't work and I didn't replace it with an led.
When I turn on the head lights the message center display and the eatc display dim like I have the dimmer turned down all the way. Turn signals, bright indicator, batt light, seat belt, all warning lights still work. The only thing that doesn't work is every light that you can dim with the dimmer.
Could my dimmer have went bad over night? Is there a way to test it? The dimmer control still turn's the dome light on and off.
Speedo, tach everything still works.
Not sure where to go with this problem. Pulled gauge cluster back out and everything look fine. Double checked all my connections and everything is plugged in.
