kingjames924
Hello LVC!
This is my first thread here. I'm a new member but I am a fan of this site and I use it regularly for all of my LS needs. I want to thank all of you for helping me through all of my issues. Now I'm having an issue that doesnt have a clear cut answer......
I have a 2001 LS V8. It was a normal Friday in Las Vegas. I get into my car after work and had no issues prior. My power seat stopped working, and the memory seat button didnt work as well. it only adjusted the steering wheel and mirrors.
When i turned on the car, it started to idle high around 2000 rpm and stay there. then went back down briefly, then high again. I drove home, looked on this wonderful site and saw that it could be the IACV. So i planned my sunday around an attempted cleaning of the IACV.
Saturday i went to the store just to see if it was a fluke, and the master control for the windows stopped working, so i couldnt open or close my windows. tried the other windows and they went down only on each doors individual switch.
Sunday, me and my friend cleaned out the throttle body along with the IACV. The problem persisted along with all of the other issues. I sat down in the drivers side of my car with the thought of buying a new IACV. when i sat down the idle went back to normal, the seat worked and the windows worked. I got back up and the problems happened again. Sat down, it was fixed again.
My friend smacked the power seat buttons with the screwdriver, and everything started working again. i readjusted the seat to go back up. and no more idle problems since.
But now my power seat and windows work intermittently (aka sometimes they do sometimes they dont). I can get it to work temporarily by removing and replacing the 20a fuse in slot 21. Something i did notice, is that the relays are warmer than normal. they are supposed to be the temp of everything else in the area, but are warm borderline hot.
So i have 3 questions at this point.
1: What do you think could be wrong with the windows and power seat?
2: Is there a wire that goes under the carpet that could be frayed or short that can cause the IACV to malfunction?
3: Could the fusebox and adjoining wires be the cause of this whole thing, especially with the relays being warm?
All help is appreciated and respected! Thank you in advance
