Football
Hello,
I have a Lincoln Ls 2000.
My degas bottle was cracked and I replaced it, followed the bleeding procedure to a "T". Here is my problem. No heat.
After reading the threads I thought it might be the DCCV but pretty sure its not, because the temp is the same on both sides. After running it above 2000 rpm I will get some heat, but not HOT, but ok. The 3 aluminum tubes that come from the DCCV are hot. What I don't understand is that once I shut it down, It won't get hot again and have to do it Every time I start the car and need the heat.
Could this be a thermostat Problem? It doesn't over heat, Temp gage is good... So damn confused.
Any suggestions?
Thanks
Any suggestions?
Thanks
