Blueberryyum02
Ok I been fighting this no heat situation after I replaced all plastic, the last thing I replaced was the degass bottle and suddenly no heat.
Dreading the fact I bought the dorman bottle, I suspected that's my problem, nope finally got around to unplugging the DCCV after countless days of bleeding, and fooling around with the degass bottle, it's suppose to default to full heat right nope nothing. The hose from the tee leading to it is cold and lacks pressure also the heater core hoses are cold and lacks pressure. Which I'm leaning towards the valve is stuck in a closed state which is stopping the flow of coolant. Which means I still have air in the system.
What I don't understand is why would the heater bleed show signs of coolant if indeed the valve is in a closed position?
The only time I get a good stream is if I give it gas, and that only happens after it's released then I goes back to a trickle where it stops then trickle and so fourth and so on.
