Isaac-1200
Ok guys I'm Isaac and I've been driving my 89 lincoln mark vii lsc everyday since july. Earlier tonight my alternate bearing went bad and it locked up then burnt my belt. No problem for me. got it fixed. not even drivin 3 minutes down the down the road my lights shut off an my engine bogs down! so i pull over and i smell tht nasty electic crap. The key is on but nothing else is no lights no gauge lights no radio nothing! I replaced the solenoid still nothing. No power to anything. I read that a bad ignition switch can burn out the fuse links. i cut a couple of them open but i have no idea how to check if they are bad. I will say i know my ignition switch is bad i have it rigged with a piece of string to stay in place. My question. What should i start replacing to get my driver back on the road? Ignition switch? then the fusable links? and if they dont fix it then what? Do I take it to a garage? I mean i am pretty well rounded with this crap. If i cannot get it then its scrap time or im gonna carb it with a push button ignition which id rather not do. It only has 65k miles on it 4k of which i put on.
Thanks guys I really appreciate it and if i win the lottery one day you all get a slice
