no cluster or interior trim lights?
starfox86
Cape Coral
I think i blew a fuse or a relay but I can't seem to find ANY bad fuses. I've checked all three boxes. I don't know what relay would be used for this though. I currently have no lights on the cluster although the miles and trip readings still work. The dome map lights and door foot lights work but none of the shifter, window, door locks work. Any ideas on how to fix this? :confused:
Did you check the dimmer switch? Sounds dumb but I've seen it happen before. Also, sometimes those types of switches can go bad.
Maybe it went bad then?? The A/C control lights are always lit. I don't remember if those were dimming lights too. I will check the dimmer switch again.
JUST CHECKED...the dimmer switch is working. It dims the milage, the a/c control lights, and the dome lights. Those are the only things working.
This is pissing me off...
