You say you changed those parts chasing the problem, do you mean that before you started changing the parts your brake pedal would touch the floor? Did this happen randomly? All of a sudden it just wouldn't brake or it happened gradually over time? I'm just brainstorming here, but could a frozen/faulty caliper cause this? The only time I had something similar happen to what your describing happen is when I had the rear brakes changed and the person at the shop who did it actually broke the caliper turning mechanism (I'm not sure what it's called), causing it to seize. Once I got a new caliper the issue was resolved.
