no.11 fuse keeps shorting out on my 93mk
newguy
chicago
its the fuse that releases your shifter and emergency flashers and I think brake lights,but those two for sure,also my radio don't work and when the car is off my radio makes a cracking sound threw the speakers like it wants to go on,but like I said my key is off,maybe my radio has a short causing my no.11 fuse to burn out,also my battery sparks when I put on the cables??something shorting out ???>HELP
Probably frayed wire some where.
That is pretty common on the mark 8's.
Open the trunk.. look near the drivers side trunk hinge..
you'll see the wire harness for the rear lights.
Betcha, those wires have gotten cut by the the carpet for the trunk.
The wires move when you open and close the trunk and they fray on the backing of the trunk carpet.
you should see 2-3,5 cut or frayed wires in that location.
hope this helps
no the fuse that works the hazerts and shifter release,that fuse could it be a bad radio(shorting out that fuse cause my radio is making noises when the power is off,and it don't work also when car is on
