ground_zero298
I've been lookin to upgrade the conti (don't laugh) and was lookin at the new zex traction control system .(dry shot) would skip first and then set the low and high rpm range. It's only active at wot. If I keep it between the shift points do you think that would be ok to run? Also what are some of the down side to runnin nos. I'm not gonna use it all the time. I already have a 80mm maf, custom cold air intake, triple x pipe with flow master 40's, rear o2 sensor shut off. custom tune. Car dynoed alittle over 320. I know i'm already pushin the trans, but wondered if staying between the shift point with another 100 horrse would be safe. Not lookin to have the fastest car but don't wanna get punked out at the red light either. would have posted in the conti forum but their ideas of upgrades seem to be stero equipment(no offense) If it would be safe I figure I would need bigger injectors and fuel rails?
