new trick
tegra1027
Waukegan
I learned a new trick today to read the codes on ur LS' computer. It only works on the LS, no other lincoln.
For some LS's on the climate control, you press the 'off' button and the 'floor' button at the same time. And then within two seconds, press the 'auto' button.
If that doesnt work, press the 'off' button and the 'defrost' button at the the same time, and then press the 'auto' button within two seconds.
on the climate control display, numbers will start being read, if there are codes it will flash the codes. if there are no codes the display will fill up with all the backlights.
To clear the display, just press the off button.
I thought it was pretty cool. A lot of you probably already know this but there u go.
for the climate control codes yea..Marks got the same thing along with most f/l/m's with eatc.
