new rear airbags
normohl
rattman
i installed 2 new arrnot airbags on the rear of my mark. the passanger side sits the same as the front, but the drivers side rear is about an inch lower than the rest of the car, there is no audible leakage and no over pumping just an inch lower. i only replaced the 2 o-rings that connect the soloniod to the bag itself.
the air-spring came with 4 different o-rings one huge one, one tiny one, and the 2 for the seal for the air itself. i did not use the big ones or the little ones on either side - just the 2 for the solenoid seal - and one side is sitting fine and the other is not. thanks.
Turn the switch of and give it a day or two and see if it drops. If not the bags aren't leaking. The front bags could not be set to the same height or one of the, is leaking slowly. The rear has one height sensor for both bags.
